It is currently Sun Sep 14, 2025 1:19 pm
 Post subject: Chalk or carbon paper
PostPosted: Mon May 26, 2025 8:07 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I planned on fitting a dovetail neck yesterday but, I couldn't find either chalk or paper. In addition, my back was screaming for some reason so I gave up for the day.
Before I order, I'd like to know your preferences. I have no plan of going into the shop today so I'll wait for your responses.
Hutch
PostPosted: Mon May 26, 2025 8:09 am
We use chalk.
These users thanked the author Hesh for the post: banjopicks (Mon May 26, 2025 10:19 am)
PostPosted: Mon May 26, 2025 8:18 am
First name: Richard
City: Warwick
State: RI
Hesh wrote:
We use chalk.
I've had good luck with chalk in the past and I'm leaning towards it. Any specific type or brand?
Hutch
These users thanked the author banjopicks for the post: Hesh (Mon May 26, 2025 8:27 am)
PostPosted: Mon May 26, 2025 8:28 am
Just plan old blue chalk from the tool section of a hardware store, comes in chunks.
PostPosted: Mon May 26, 2025 9:55 am
chalk for me
These users thanked the author bluescreek for the post: banjopicks (Mon May 26, 2025 10:18 am)
PostPosted: Mon May 26, 2025 11:51 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Chalk for the win, carbon paper not so much.
Measure Twice,
Karl Borum
PostPosted: Mon May 26, 2025 5:11 pm
First name: Richard
City: Warwick
State: RI
I suck at this. More shims.
Hutch
These users thanked the author banjopicks for the post: Hesh (Tue May 27, 2025 5:42 am)
PostPosted: Mon May 26, 2025 9:24 pm
Chalk
I heard the dovetail called "The devils joint".......
These users thanked the author Brad Goodman for the post (total 2): Kbore (Tue May 27, 2025 9:51 am) • Hesh (Tue May 27, 2025 5:42 am)
PostPosted: Wed May 28, 2025 7:00 am
Chalk and swearing.
These users thanked the author guitarjtb for the post: Kbore (Wed May 28, 2025 4:01 pm)
PostPosted: Wed May 28, 2025 9:31 am
First name: Richard
City: Warwick
State: RI
guitarjtb wrote:
Chalk and swearing.
This!
Hutch
These users thanked the author banjopicks for the post: Kbore (Wed May 28, 2025 4:01 pm)
PostPosted: Wed May 28, 2025 9:51 am
Chalk is good.
Carbon paper smears if it gets wet. Bought a nice piece of maple from a guy who left his carbon paper laying around, and it got wet. I had to cut the blue parts out....
PostPosted: Fri May 30, 2025 10:24 am
First name: Richard
City: Warwick
State: RI
It's clamped. Never again without a mentor. My next body already has a mortise.
Hutch
PostPosted: Fri May 30, 2025 10:44 am
First name: Richard
City: Warwick
State: RI
On top of that, what kind of sandpaper do you use for sliding and adjusting the angle. I used 100 grit belt sander paper cloth. It took forever to remove any wood and I only had an 8th or less at the edge of that makes sense.
Hutch
PostPosted: Fri May 30, 2025 1:02 pm
City: U.P.
I do my flossing with fresh 320. It has lots of grit so it cuts uniformly, evenly and smoothly. I cut half a sheet in 1" strips x 8" long.
It is thin so conforms to the body which is what you want.
Cloth sanding belts IMO are too stiff and too thick and 100 grit is way overkill. That should have removed your 1/8" of wood in short order, probably too fast for the job at hand where accuracy is more important than speed. Was your sanding belt material used?
Fitting a neck joint is a finesse job not a muscle job.
To answer the original question, chalk, white blackboard chalk.
Brian R, Wood Mechanic
N8ZED
PostPosted: Sat May 31, 2025 6:10 am
First name: Richard
City: Warwick
State: RI
I had the cheeks fitting perfect right up til I glued and clamped. Then this.and after staring at this, i realized where I went wrong installing the fretboard and nut. This is why there's such a big space between the pick guard and bridge. Also why my drill but didn't hit the pocket when I reset the neck.
On the good side, I got exactly what.
Hutch
Users browsing this forum: No registered users and 129 guests
